Ana içeriğe geç
Sony Walkman D-E356CK Back Panel Replacement
Neye ihtiyacın var
  1. Sony Walkman D-E356CK Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Open the battery compartment.
    • Remove the AA batteries from within the compartment.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Walkman D-E356CK Back Panel Replacement: adım 2, 3 resimden 1. Sony Walkman D-E356CK Back Panel Replacement: adım 2, 3 resimden 2. Sony Walkman D-E356CK Back Panel Replacement: adım 2, 3 resimden 3.
    • Press the button located in the bottom left corner of the device labeled "open."
    • Remove the three 11 mm-long Phillips screws.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Walkman D-E356CK Back Panel Replacement: adım 3, 2 resimden 1. Sony Walkman D-E356CK Back Panel Replacement: adım 3, 2 resimden 2.
    • Remove the two 11 mm-long Phillips screws on the back side of the Walkman.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Walkman D-E356CK Back Panel Replacement: adım 4, 2 resimden 1. Sony Walkman D-E356CK Back Panel Replacement: adım 4, 2 resimden 2.
    • Insert an opening tool into the seam between the back panel and chassis.
    • Pry around the perimeter until the back panel releases.
    • Remove the back panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Aiden Pacheco
136 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Botvin Fall 2025 UMass Dartmouth, Team 1-1, Botvin Fall 2025 üyesi
UMASSD-BOTVIN-F25S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 101
