Ana içeriğe geç
Sony Walkman NWZ-E438 Battery Replacement
Neye ihtiyacın var
  1. Sony Walkman NWZ-E438 Battery Replacement, Disassembling Sony Walkman NWZ-E438: adım 1, 1 resimden 1.
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Battery Replacement: adım 2, 1 resimden 1.
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Peel back the black tape from the device to the battery from the side of the device.
  4. Sony Walkman NWZ-E438 Battery Replacement: adım 4, 1 resimden 1.
    • Using a small, plastic prying tool slowly lift the battery around all edges.
    • Careful of wires connecting the battery to the device.
  5. Sony Walkman NWZ-E438 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the yellow film covering the circuit board with pointed precision tweezers.
  6. Sony Walkman NWZ-E438 Battery Replacement: adım 6, 2 resimden 1. Sony Walkman NWZ-E438 Battery Replacement: adım 6, 2 resimden 2.
    • Using tweezers, unplug the gold band connecting the device and circuit board.
  7. Sony Walkman NWZ-E438 Battery Replacement: adım 7, 2 resimden 1. Sony Walkman NWZ-E438 Battery Replacement: adım 7, 2 resimden 2.
    • Using pointed precision tweezers, unplug the wires connecting the battery and chip from the chip.
  8. Sony Walkman NWZ-E438 Battery Replacement: adım 8, 1 resimden 1.
    • Remove battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Do you have a link to purchase a replacement battery? Thanks!
jacob goff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 6,446
