Ana içeriğe geç
Sony Walkman NWZ-E438 Screen Replacement
Neye ihtiyacın var
  1. Sony Walkman NWZ-E438 Screen  Replacement, Disassembling Sony Walkman NWZ-E438: adım 1, 1 resimden 1.
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Screen  Replacement: adım 2, 1 resimden 1.
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Screen  Replacement, Screen: adım 3, 1 resimden 1.
    • Pull up the 2 copper strips connecting the outside of the device to the inside of the device.
  4. Sony Walkman NWZ-E438 Screen  Replacement: adım 4, 1 resimden 1.
    • Using the small, plastic prying tool wedge it between the bottom of the frame and the outer frame.
    • Slowly circle the device, popping the outside of the frame off.
  5. Sony Walkman NWZ-E438 Screen  Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • To remove the screen, use the fine point tweezers and lift up on the metal piece at the bottom of the frame.
  6. Sony Walkman NWZ-E438 Screen  Replacement: adım 6, 1 resimden 1.
    • To remove screen from metal backing, use fine point tweezers to go in between the screen and metal backing and slowly pull them apart.
  7. Sony Walkman NWZ-E438 Screen  Replacement: adım 7, 1 resimden 1.
    • The screen will be removed.
Sonuç
Bir Yorum
wher buy display
Pavel Drobny - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 713
