Ana içeriğe geç
Sony Walkman NWZ-S764 Bluetooth module Replacement
Neye ihtiyacın var
  1. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: adım 1, 3 resimden 1. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: adım 1, 3 resimden 2. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: adım 1, 3 resimden 3.
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 2, 3 resimden 1. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 2, 3 resimden 2. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 2, 3 resimden 3.
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 3, 2 resimden 1. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 3, 2 resimden 2.
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 4, 2 resimden 1. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 4, 2 resimden 2.
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: adım 5, 3 resimden 1. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: adım 5, 3 resimden 2. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: adım 5, 3 resimden 3.
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 6, 3 resimden 1. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 6, 3 resimden 2. Sony Walkman NWZ-S764 Bluetooth module Replacement: adım 6, 3 resimden 3.
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
Sonuç
John Ferguson
657 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Brown Winter 2015 USF Tampa, Team 4-2, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 658
