Ana içeriğe geç
Sony Walkman WM-AF48 Film Revolver Band Replacement
Neye ihtiyacın var
  1. Sony Walkman WM-AF48 Film Revolver Band Replacement, Getting started: adım 1, 1 resimden 1.
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: adım 2, 3 resimden 1. Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: adım 2, 3 resimden 2. Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: adım 2, 3 resimden 3.
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Film Revolver Band Replacement, Replace the band: adım 3, 1 resimden 1.
    • Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
  4. Sony Walkman WM-AF48 Film Revolver Band Replacement, Belt track: adım 4, 1 resimden 1.
    • This picture shows how the belt was set when I opened a Walkman WM-FX10.
    • I think you can rely on the same arrangement in other Walkman's
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Wilson Riforgiat
931 İtibar
4 adet Kılavuz yazıldı
Ekip
3Kılavuz Yorumları
"How to replace the band":
Step 1: Open it.
Step 2: Replace the band.
Really? That's it?! Not very useful.
No Thanks - Yanıt Paylaş
I need to know the belt track. I'm thinking there is a particular path the belt must follow. Do you know it? Your photo shows no belt (band).
jcalla704 - Yanıt Paylaş
Helped. Wanted an idea of how to open, before breaking it!
Troyf - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 30
Son 30 gün: 125
Her zaman: 19,613
