Giriş
If you are unable to hear any kind of audio on your Sony Walkman, it is possible that you may need to replace the headphone jack. This can be a little tricky for this particular model, but not impossible. To do this, you will need a spudger and a soldering iron.
Neye ihtiyacın var
Gently pull the ribbon from the jack just above the film revolver, near the edge.
Carefully lift the motherboard out of the outer shell.
Locate the four metal points on the motherboard that hold the headphone jack in place.
Using a soldering iron, remove the headphone jack by de-soldering the four points that hold it in place.
7 farklı kişi bu kılavuzu tamamladı.
