Ana içeriğe geç
Sony Walkman WM-AF48 Power Switch Replacement
Neye ihtiyacın var
  1. Sony Walkman WM-AF48 Power Switch Replacement, Getting started: adım 1, 1 resimden 1.
    • Remove any batteries or cassettes from the Walkman.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: adım 2, 3 resimden 1. Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: adım 2, 3 resimden 2. Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: adım 2, 3 resimden 3.
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: adım 3, 2 resimden 1. Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: adım 3, 2 resimden 2.
    • Gently pull the ribbon from the jack above the film revolver, near the edge.
    • Lift the motherboard from the outer shell.
    • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Walkman WM-AF48 Power Switch Replacement, Remove the power switch: adım 4, 1 resimden 1.
    • Identify the six points where the power switch is soldered to the motherboard.
    • Using a soldering iron, remove the switch by de-soldering these points which hold it in place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wilson Riforgiat
931 İtibar
4 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Hi,
Where would you find a Vintage Sports Sony Walkman power switch ? Battery light is on one function and then turns off on the other. Other than this, the unit is in EXCELLENT Condition. THANKS for any insight and for helping us :)
Pamela Osborne - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 33
Her zaman: 2,502
