Ana içeriğe geç
Sony XAV-AX100 Display Board Replacement
Neye ihtiyacın var
  1. Sony XAV-AX100 Display Board Replacement, USB Cable: adım 1, 3 resimden 1. Sony XAV-AX100 Display Board Replacement, USB Cable: adım 1, 3 resimden 2. Sony XAV-AX100 Display Board Replacement, USB Cable: adım 1, 3 resimden 3.
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Display Board Replacement: adım 2, 2 resimden 1. Sony XAV-AX100 Display Board Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Display Board Replacement: adım 3, 1 resimden 1.
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Display Board Replacement: adım 4, 1 resimden 1.
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Display Board Replacement: adım 5, 3 resimden 1. Sony XAV-AX100 Display Board Replacement: adım 5, 3 resimden 2. Sony XAV-AX100 Display Board Replacement: adım 5, 3 resimden 3.
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Display Board Replacement, Motherboard: adım 6, 2 resimden 1. Sony XAV-AX100 Display Board Replacement, Motherboard: adım 6, 2 resimden 2.
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Display Board Replacement: adım 7, 3 resimden 1. Sony XAV-AX100 Display Board Replacement: adım 7, 3 resimden 2. Sony XAV-AX100 Display Board Replacement: adım 7, 3 resimden 3.
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Display Board Replacement, Display: adım 8, 1 resimden 1.
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Display Board Replacement: adım 9, 2 resimden 1. Sony XAV-AX100 Display Board Replacement: adım 9, 2 resimden 2.
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
  10. Sony XAV-AX100 Display Board Replacement, Display Board: adım 10, 3 resimden 1. Sony XAV-AX100 Display Board Replacement, Display Board: adım 10, 3 resimden 2. Sony XAV-AX100 Display Board Replacement, Display Board: adım 10, 3 resimden 3.
    • Remove the four 3.5mm Phillips #0 screws from the display board.
    • Remove the black tape using a precise tweezer.
    • Remove the 3.5mm Phillips #0 screw from underneath the tape.
  11. Sony XAV-AX100 Display Board Replacement: adım 11, 1 resimden 1.
    • Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the back plate.
  12. Sony XAV-AX100 Display Board Replacement: adım 12, 1 resimden 1.
    • Remove the single 2mm Phillips #0 screw from the motherboard.
  13. Sony XAV-AX100 Display Board Replacement: adım 13, 1 resimden 1.
    • Use a plastic opening tool to remove the display board from the radio.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abdulaziz Redha
741 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Cagle Spring 2018 USF Tampa, Team S1-G5, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G5
2 Üyeler
Bir Yorum
Where can I purchase the touch panel glass screen?
Steven olivarez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 1,905
