Giriş
By following this repair guide, you will be able to replace your Screen Motherboard. Therefore, your device will take less time processing high resolution images and information.
Neye ihtiyacın var
Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
Remove the ten 3.5mm Phillips #0 screws from the back plate.
Disconnect the display power cable from the motherboard.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Remove the four 3.5mm Phillips #0 screws from the display board.
Remove the black tape using a precise tweezer.
Remove the 3.5mm Phillips #0 screw from underneath the tape.
Bir başkası bu kılavuzu tamamladı.
