Ana içeriğe geç
Giriş
This repair guide will demonstrate how to properly replace your Main Motherboard on your device. By doing so, you can crucially extend the lifespan of your device. In addition, you will also experience much faster response time from your device.
  1. Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards. Remove the ten 3.5mm Phillips #0 screws from the back plate. Remove the ten 3.5mm Phillips #0 screws from the back plate.
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Use a plastic opening tool to remove the back plate. Don't remove completely as there will still be cables connected.
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Disconnect the USB cable from the display board.
    • Disconnect the USB cable from the display board.
  4. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  5. Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  6. Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel. Pull the USB cable off of the back plate. Pull the USB cable off of the back plate.
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  7. Disconnect the display power cable from the motherboard. Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  8. Unscrew the four 3.5mm Phillips #0 screws from the motherboard. Use a spudger to gently lift the motherboard up and out of the radio. Use a spudger to gently lift the motherboard up and out of the radio.
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
Sonuç
Abdulaziz Redha
657 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team S1-G5, Cagle Spring 2018 USF Tampa, Team S1-G5, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 8
Son 30 Gün: 21
Her zaman: 307
