Ana içeriğe geç
Giriş
This repair guide will help you install a new USB cable for your car unit. It will ultimately enhance your experience while connecting the device to your car. This process requires you having a tool kit, specifically, the PH#0 screwdriver and a spudger. With that said, you should be good to go!
Parçalar
Hiçbir parça belirtilmedi.
  1. Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards. Remove the ten 3.5mm Phillips #0 screws from the back plate. Remove the ten 3.5mm Phillips #0 screws from the back plate.
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Use a plastic opening tool to remove the back plate. Don't remove completely as there will still be cables connected.
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  4. Disconnect the USB cable from the display board.
    • Disconnect the USB cable from the display board.
  5. Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  6. Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel. Pull the USB cable off of the back plate. Pull the USB cable off of the back plate.
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
Sonuç
Abdulaziz Redha
657 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team S1-G5, Cagle Spring 2018 USF Tampa, Team S1-G5, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 7
Son 30 Gün: 37
Her zaman: 516
