Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Sony XAV-AX100 USB Cable Replacement
Neye ihtiyacın var
  1. Sony XAV-AX100 USB Cable Replacement, USB Cable: adım 1, 3 resimden 1. Sony XAV-AX100 USB Cable Replacement, USB Cable: adım 1, 3 resimden 2. Sony XAV-AX100 USB Cable Replacement, USB Cable: adım 1, 3 resimden 3.
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 USB Cable Replacement: adım 2, 2 resimden 1. Sony XAV-AX100 USB Cable Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 USB Cable Replacement: adım 3, 1 resimden 1.
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 USB Cable Replacement: adım 4, 1 resimden 1.
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 USB Cable Replacement: adım 5, 3 resimden 1. Sony XAV-AX100 USB Cable Replacement: adım 5, 3 resimden 2. Sony XAV-AX100 USB Cable Replacement: adım 5, 3 resimden 3.
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abdulaziz Redha
741 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Cagle Spring 2018 USF Tampa, Team S1-G5, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G5
2 Üyeler
3 Yorum
Where i can get replacement lead?
mudylla - Yanıt
where can i get a replacement lead for this please
Andy 777 - Yanıt
im in the UK
Andy 777 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 52
Her zaman: 4,074
