Giriş
By replacing your Volume Knob, you will certainly turn up/down the volume of your music much smoother. Since this is the most usable button of the device, it will defiantly have a lower performance on the long run.
Neye ihtiyacın var
Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
Remove the ten 3.5mm Phillips #0 screws from the back plate.
Disconnect the display power cable from the motherboard.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Remove the four 3.5mm Phillips #0 screws from the display board.
Remove the black tape using a precise tweezer.
Remove the 3.5mm Phillips #0 screw from underneath the tape.
Remove the silver knob cover by pulling upwards on it.
Remove the plastic face plate.
Pull off the black knob.
Bir başkası bu kılavuzu tamamladı.
