Neye ihtiyacın var
Remove the batteries.
Remove 4 cross-head screws from the rear of the case and a fifth in the battery compartment.
The back should now lift off.
Remove the aerial retaining screw.
Lift the aerial slightly in order to release the aerial connecting tag. You can now put the case rear cover aside.
Pull off the volume knob.
To remove the tuning knob, gently prise it off with a jimmy.
Under the tuning knob you will see a spring. Note its position for reassembly and remove it, taking care it doesn't take flight.
Unsolder the two wires connecting to the loud speaker. (This is not essential but will save you from straining these wires.)
Remove 2 screws from the grey midframe, one on the lower right on the battey connector and the other on the upper left above the tuning knob.
Release the two cables from their retaining clips under the battery compartment.
Lift the grey battery connector slightly to disengage a bush where you removed a screw in the previous step. (On reassembly, ensure this is snapped back in place.)
Ease the power and headphone sockets out of their holes in the case, using a spudger or similar tool.
You can now lift the midframe and attached assemblies out of the case, first lifting the right hand side by the power and headphone sockets, and hence withdrawing the volume and tuning spindles from the left hand side.
Unsolder the connection on thecircuit board to the DAB tuner module below.
Remove two screws marked on the circuit board (marked on the board with arrows).
The circuit board is attached to the DAB radio module beneath by a multi-way connector. Gently lift the right hand side of the board in order to release it.
The DAB radio module will now simply lift out.
