Ana içeriğe geç
Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement
Neye ihtiyacın var
  1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: adım 1, 3 resimden 1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: adım 1, 3 resimden 2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: adım 2, 3 resimden 1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: adım 2, 3 resimden 2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: adım 2, 3 resimden 3.
    • Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
    • Lift the camera from the right and simply wiggle out of the slot.
  3. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: adım 3, 3 resimden 1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: adım 3, 3 resimden 2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: adım 3, 3 resimden 3.
    • Disconnect the back camera from the port located in the upper right corner.
    • Lift up the camera cable using the tweezers.
    • Wiggle out camera from the slot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Martin Luna
1.858 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 üyesi
USFT-REMMELL-F14S15G6
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 2,957
