Ana içeriğe geç
Sony XPERIA Tablet Z Micro USB Port Replacement
Neye ihtiyacın var
  1. Sony XPERIA Tablet Z Micro USB Port Replacement, Micro USB Port: adım 1, 3 resimden 1. Sony XPERIA Tablet Z Micro USB Port Replacement, Micro USB Port: adım 1, 3 resimden 2. Sony XPERIA Tablet Z Micro USB Port Replacement, Micro USB Port: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Micro USB Port Replacement: adım 2, 3 resimden 1. Sony XPERIA Tablet Z Micro USB Port Replacement: adım 2, 3 resimden 2. Sony XPERIA Tablet Z Micro USB Port Replacement: adım 2, 3 resimden 3.
    • Located in the bottom left of the device you will remove the two screws holding the metal plate on the USB port.
    • Remove metal plate
    • Remove plastic securing the USB port.
  3. Sony XPERIA Tablet Z Micro USB Port Replacement: adım 3, 3 resimden 1. Sony XPERIA Tablet Z Micro USB Port Replacement: adım 3, 3 resimden 2. Sony XPERIA Tablet Z Micro USB Port Replacement: adım 3, 3 resimden 3.
    • Remove screw with screw diver and lift metal plate with tweezers.
    • Pick up left end of the electrical tape
    • Lift up to remove USB plug from the mounting location.
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Martin Luna
1.873 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 üyesi
USFT-REMMELL-F14S15G6
3 Üyeler
7 adet Kılavuz yazıldı
14Kılavuz Yorumları
Thank you! easy and straight forward.
Any suggestions on an adhesive for the back cover?
Heath240 - Yanıt
I was able to replace the usb port but my tablet still wont charge or be recognized as usb when connected to PC. What can this be? Any idea? Please I need help.
esteeizaola - Yanıt
I also replace charging port with same result, I was not able to find a solution online so until I can find a magnetic docking station for sale I have bypassed the charging port and connected my usb direct to the battery with 100% result.
My tablet never goes outdoors so the waterproof covers is not needed, bloody well good job as there now is a usb cable poking out the cover and sealed closed with electrial type
Higgs -
I was able to replace my connector after much difficulty (the part I received wasn't the exact size so I had to cut a little bit and force a lot!). I worked great... For approx. 2 weeks. Now I'm back to square one. I was wondering if it would be possible to fabricate a magnetic dock (or similar), since the official one seems impossible to find?
Lynx -
I replaced the usb port and had the same problem as esteeizola because my battery was completely drained. (IMHO Sony has a design fault with their USB ports. They are rubish. If you get more than 200 plug/unplug operations out of a Sony USB you are very lucky).
What happened was that USB drew 4 to 5 milli-amps for about 10 to 12 amps. During this time the red led was lit but the device remained dead. Finally, USB started drawing a normally charging current (a very pathetic 300 milli-amps from what I can tell.) And the device came to life say the battery was 2% charged.
I don't what the reason is for this behavior but it certainly is very confusing and frustrating,
Peter Moy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 53
Her zaman: 31,136
