Ana içeriğe geç
Sony XPERIA Tablet Z Screen Replacement
Neye ihtiyacın var
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: adım 1, 3 resimden 1. Sony XPERIA Tablet Z Screen Replacement, Screen: adım 1, 3 resimden 2. Sony XPERIA Tablet Z Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: adım 2, 3 resimden 1. Sony XPERIA Tablet Z Screen Replacement: adım 2, 3 resimden 2. Sony XPERIA Tablet Z Screen Replacement: adım 2, 3 resimden 3.
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: adım 3, 1 resimden 1.
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: adım 4, 1 resimden 1.
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: adım 5, 1 resimden 1.
    • Clean adhesive from perimeter of frame to prepare for new screen.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Gustavo Correa
373 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S5-G1, Harley Summer 2017 IUPUI, Team S5-G1, Harley Summer 2017 üyesi
IUPUI-HARLEY-SU17S5G1
4 Üyeler
3 adet Kılavuz yazıldı
5Kılavuz Yorumları
اريدشراءاريدشراءشاشه جديده
kore ares - Yanıt
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Yanıt
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Yanıt
Wooo its self explanatory.Good work
Duncan Mwaniki - Yanıt
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 8,032
