Ana içeriğe geç
Sony XPERIA Tablet Z Volume Button Replacement
Neye ihtiyacın var
  1. Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: adım 1, 3 resimden 1. Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: adım 1, 3 resimden 2. Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
    • Disconnect battery, to avoid electric shock, by pulling up on the white plastic as shown by the orange box.
  2. Sony XPERIA Tablet Z Volume Button Replacement, Locate the Volume module: adım 2, 1 resimden 1.
    • Locate the volume module.
    • Remove both screws using the Philips screwdriver.
  3. Sony XPERIA Tablet Z Volume Button Replacement, Lift out of Place: adım 3, 1 resimden 1.
    • Once both screws are removed grab the tweezers.
    • Then lift up on the module.
  4. Sony XPERIA Tablet Z Volume Button Replacement, Removing the Electrical tape: adım 4, 1 resimden 1.
    • Find the electrical tape connecting the module to the motherboard
    • Carefully pull out the electrical tape horizontally and remove the volume module from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Martin Luna
1.873 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 üyesi
USFT-REMMELL-F14S15G6
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 2,454
