Ana içeriğe geç
Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: adım 1, 3 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: adım 1, 3 resimden 2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: adım 1, 3 resimden 3.
    • Switch-off the phone.
    • Remove the battery.
  2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 2, 3 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 2, 3 resimden 2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 2, 3 resimden 3.
    • The small bottom bezel is held by 2x locking clips.
    • Preferably use plastic tools for disassembling.
  3. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 3, 3 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 3, 3 resimden 2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 3, 3 resimden 3.
    • There are 4x silver screws and 3x black screws.
    • The rear cover is held by 5x locking clips.
    • Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
  4. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 4, 3 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 4, 3 resimden 2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 4, 3 resimden 3.
    • Remove the back cover.
    • With a plastic tool disconnect one by one:
    • LCD Display flex cable
    • Touchscreen flex cable
    • Menu Buttons Board flex cable
    • Coaxial Wire Antenna cable
  5. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 5, 2 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 5, 2 resimden 2.
    • Carefully remove the main board.
  6. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 6, 3 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 6, 3 resimden 2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 6, 3 resimden 3.
    • Disconnect the other side of the flex cable and remove the Home Buttons board.
    • Unstick the camera button.
  7. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 7, 3 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 7, 3 resimden 2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 7, 3 resimden 3.
    • The touch screen is stuck to the frame with double side adhesive tape.
    • By using plastic tools gently start separating.
    • At the bottom is glued on firmly because the bonded surface is larger.
    • Use a hot air to make separating more easy and safety.
  8. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 8, 3 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 8, 3 resimden 2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 8, 3 resimden 3.
    • With a plastic tool, carefully separate the LCD display from the touch screen.
    • Clear the touchscreen from the old adhesive tape.
  9. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 9, 3 resimden 1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 9, 3 resimden 2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 9, 3 resimden 3.
    • Install the new LCD into the frame and put adhesive tape.
    • Be careful not to cover the holes (for the speaker, menu buttons etc.). Install the Touchscreen.
  10. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: adım 10, 1 resimden 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
ZFix
191.278 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
2 Yorum
Sir
Please help
Mera phone SONY C1504
Display connector kharab ho gya
Hai new mil sakta hai
Please help
Yogendra Singh - Yanıt
Jo PCB main hota hai
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,974
