Ana içeriğe geç
Sony Xperia J Camera Replacement
Neye ihtiyacın var
  1. Sony Xperia J Camera  Replacement, External Features: adım 1, 1 resimden 1.
    • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Xperia J Camera  Replacement: adım 2, 1 resimden 1.
    • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Xperia J Camera  Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Xperia J Camera  Replacement: adım 4, 3 resimden 1. Sony Xperia J Camera  Replacement: adım 4, 3 resimden 2. Sony Xperia J Camera  Replacement: adım 4, 3 resimden 3.
    • Using the Torx T5 screwdriver remove the four 4.74mm screws.
    • Then remove the two 3.13mm screws
    • Lastly remove 5.90mm screw.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Xperia J Camera  Replacement: adım 5, 3 resimden 1. Sony Xperia J Camera  Replacement: adım 5, 3 resimden 2. Sony Xperia J Camera  Replacement: adım 5, 3 resimden 3.
    • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
    • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Xperia J Camera  Replacement: adım 6, 1 resimden 1.
    • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Xperia J Camera  Replacement: adım 7, 1 resimden 1.
    • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
    FixBot'a Sor
    Yorum Ekle
  8. Sony Xperia J Camera  Replacement, Removing Parts: adım 8, 1 resimden 1.
    • Using the tweezers remove the clip located at the top of the phone. It should snap right off without too much pressure.
    FixBot'a Sor
    Yorum Ekle
  9. Sony Xperia J Camera  Replacement: adım 9, 1 resimden 1.
    • Then remove the sticky pad located at the left of the phone using he tweezers.
    FixBot'a Sor
    Yorum Ekle
  10. Sony Xperia J Camera  Replacement, Removing Parts: adım 10, 3 resimden 1. Sony Xperia J Camera  Replacement, Removing Parts: adım 10, 3 resimden 2. Sony Xperia J Camera  Replacement, Removing Parts: adım 10, 3 resimden 3.
    • Using the tweezers lift the plate out of the clamps, from left to right.
    • Then remove the whole plate off the phone.
    • The plate might be a little sticky due to the glue used when assembling the phone.
    FixBot'a Sor
    Yorum Ekle
  11. Sony Xperia J Camera  Replacement, Removing Parts: adım 11, 1 resimden 1.
    • Using the tweezers, slowly peel the white sticker off from the top right corner to the left bottom corner.
    FixBot'a Sor
    Yorum Ekle
  12. Sony Xperia J Camera  Replacement, Removing Parts: adım 12, 3 resimden 1. Sony Xperia J Camera  Replacement, Removing Parts: adım 12, 3 resimden 2. Sony Xperia J Camera  Replacement, Removing Parts: adım 12, 3 resimden 3.
    • Once the sticker is off, unclip the clip on the top left side(below the camera). Then slide out the wide orange cable below the clip.
    • Then lift up the board carefully and remove the clip and cable on the back.
    FixBot'a Sor
    Yorum Ekle
  13. Sony Xperia J Camera  Replacement, Removing the Camera: adım 13, 2 resimden 1. Sony Xperia J Camera  Replacement, Removing the Camera: adım 13, 2 resimden 2.
    • Pop the camera out using your fingers, and then unclip it off the board using tweezers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Arlind
899 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Brown Winter 2015 USF Tampa, Team 4-3, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 1,014
