Ana içeriğe geç
Sony Xperia J Volume/Lock Buttons Replacement
Neye ihtiyacın var
  1. Sony Xperia J Volume/Lock Buttons Replacement, External Features: adım 1, 1 resimden 1.
    • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Xperia J Volume/Lock Buttons Replacement: adım 2, 1 resimden 1.
    • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Xperia J Volume/Lock Buttons Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Xperia J Volume/Lock Buttons Replacement: adım 4, 3 resimden 1. Sony Xperia J Volume/Lock Buttons Replacement: adım 4, 3 resimden 2. Sony Xperia J Volume/Lock Buttons Replacement: adım 4, 3 resimden 3.
    • Using the Torx T5 screwdriver remove the four 4.74mm screws.
    • Then remove the two 3.13mm screws
    • Lastly remove 5.90mm screw.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Xperia J Volume/Lock Buttons Replacement: adım 5, 3 resimden 1. Sony Xperia J Volume/Lock Buttons Replacement: adım 5, 3 resimden 2. Sony Xperia J Volume/Lock Buttons Replacement: adım 5, 3 resimden 3.
    • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
    • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Xperia J Volume/Lock Buttons Replacement: adım 6, 1 resimden 1.
    • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Xperia J Volume/Lock Buttons Replacement: adım 7, 1 resimden 1.
    • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
    FixBot'a Sor
    Yorum Ekle
  8. Sony Xperia J Volume/Lock Buttons Replacement, Volume/Lock Buttons: adım 8, 2 resimden 1. Sony Xperia J Volume/Lock Buttons Replacement, Volume/Lock Buttons: adım 8, 2 resimden 2.
    • Grabbing the silver plate you just removed, locate the volume and lock switch on the upper right of it.
    • Using the tweezers, unclip the two silicone gel clips located at the ends of the keys.
    • Once the buttons are uncliped, push the keys from the outside to the inside.(As in the second picture)
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arlind
899 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Brown Winter 2015 USF Tampa, Team 4-3, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 1,041
