Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The volume/lock buttons are located on the same silver case as the speaker. You will need to successfully remove this silver plate to get to the buttons. Use the recommended tools.
The battery should be removed before working on the phone internals.
Neye ihtiyacın var
You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
Grabbing the silver plate you just removed, locate the volume and lock switch on the upper right of it.
Using the tweezers, unclip the two silicone gel clips located at the ends of the keys.
Once the buttons are uncliped, push the keys from the outside to the inside.(As in the second picture)
Bir başkası bu kılavuzu tamamladı.
