Giriş
This guide will take you step by step through the process of replacing your Sony Xperia L2 motherboard. This guide will help those who have a inoperable or faulty motherboard to provide a fully functioning motherboard.
Parçalar
Hiçbir parçaya gerek yok.
  1. Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Use the plastic opening tool to pry the back case of the phone off.
    • Use the plastic opening tool to pry the back case of the phone off.
      • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Unclip circuit connectors from phone to motherboard.
    • Use blue plastic opening tool to pry off the motherboard.
Sonuç
Mikayla Wyatt
291 İtibar
3 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 38
Her zaman: 65
