Ana içeriğe geç
Sony Xperia L2 LTE Rear Camera Replacement
Neye ihtiyacın var
  1. Sony Xperia L2 LTE Rear Camera  Replacement, Battery: adım 1, 2 resimden 1. Sony Xperia L2 LTE Rear Camera  Replacement, Battery: adım 1, 2 resimden 2.
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Rear Camera  Replacement: adım 2, 3 resimden 1. Sony Xperia L2 LTE Rear Camera  Replacement: adım 2, 3 resimden 2. Sony Xperia L2 LTE Rear Camera  Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Rear Camera  Replacement: adım 3, 1 resimden 1.
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Rear Camera  Replacement: adım 4, 2 resimden 1. Sony Xperia L2 LTE Rear Camera  Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Rear Camera  Replacement, Motherboard: adım 5, 1 resimden 1.
    • Unclip circuit connectors from phone to motherboard.
  6. Sony Xperia L2 LTE Rear Camera  Replacement: adım 6, 3 resimden 1. Sony Xperia L2 LTE Rear Camera  Replacement: adım 6, 3 resimden 2. Sony Xperia L2 LTE Rear Camera  Replacement: adım 6, 3 resimden 3.
    • Use blue plastic opening tool to pry off the motherboard.
  7. Sony Xperia L2 LTE Rear Camera  Replacement, Rear Camera: adım 7, 2 resimden 1. Sony Xperia L2 LTE Rear Camera  Replacement, Rear Camera: adım 7, 2 resimden 2.
    • Detach the rear camera from motherboard and remove it from the device.
Sonuç
Mikayla Wyatt
303 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 170
