Giriş
If your battery does not hold charge, we will show you how to open the phone and replace the old battery.
Neye ihtiyacın var
Videoya Genel Bakış
Warm the Back Cover. You can use a hairdryer.
Use a small suction cup and plastic tools for separating the Rear panel.
Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
Disconnect the Battery Cable.
The battery is stuck to the phone fame. Use the white tape to remove it.
Li-Polymer Battery, 2230 mAh
Part number: LIS1551ERPC
17 farklı kişi bu kılavuzu tamamladı.
