Ana içeriğe geç
Sony Xperia M2 Earpiece Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia M2 Earpiece Replacement, Rear Cover: adım 1, 3 resimden 1. Sony Xperia M2 Earpiece Replacement, Rear Cover: adım 1, 3 resimden 2. Sony Xperia M2 Earpiece Replacement, Rear Cover: adım 1, 3 resimden 3.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Cover is plastic.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
  2. Sony Xperia M2 Earpiece Replacement, Battery: adım 2, 3 resimden 1. Sony Xperia M2 Earpiece Replacement, Battery: adım 2, 3 resimden 2. Sony Xperia M2 Earpiece Replacement, Battery: adım 2, 3 resimden 3.
    • Disconnect the Battery Cable.
    • The battery is stuck to the phone fame. Use the white tape to remove it.
    • Li-Polymer Battery, 2230 mAh
    • Part number: LIS1551ERPC
    • Please SUBSCRIBE to my channel ツ
  3. Sony Xperia M2 Earpiece Replacement, Logic Board: adım 3, 2 resimden 1. Sony Xperia M2 Earpiece Replacement, Logic Board: adım 3, 2 resimden 2.
    • Remove the SIM and the memory cards.
    • Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
  4. Sony Xperia M2 Earpiece Replacement: adım 4, 1 resimden 1.
    • Disconnect one by one:
    • Touchscreen flex cable
    • Proximity sensor flex cable
    • Power on, Volume buttons cable
    • SIM & Micro SD flex cable
    • Coaxial antenna cable
  5. Sony Xperia M2 Earpiece Replacement: adım 5, 2 resimden 1. Sony Xperia M2 Earpiece Replacement: adım 5, 2 resimden 2.
    • Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector.
    • Put one plastic spudger between the Logic board and the Main frame.
  6. Sony Xperia M2 Earpiece Replacement: adım 6, 3 resimden 1. Sony Xperia M2 Earpiece Replacement: adım 6, 3 resimden 2. Sony Xperia M2 Earpiece Replacement: adım 6, 3 resimden 3.
    • Step one: move aside less the left side of the board - down.
    • Step two: the left side of the Logic board must go out of the main frame.
    • For this manipulation use only plastic tools.
  7. Sony Xperia M2 Earpiece Replacement, Earpiece: adım 7, 3 resimden 1. Sony Xperia M2 Earpiece Replacement, Earpiece: adım 7, 3 resimden 2. Sony Xperia M2 Earpiece Replacement, Earpiece: adım 7, 3 resimden 3.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ZFix
191.182 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.521 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 4,235
