Ana içeriğe geç
Sony Xperia M2 Loudspeaker Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia M2 Loudspeaker Replacement, Rear Cover: adım 1, 3 resimden 1. Sony Xperia M2 Loudspeaker Replacement, Rear Cover: adım 1, 3 resimden 2. Sony Xperia M2 Loudspeaker Replacement, Rear Cover: adım 1, 3 resimden 3.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Cover is plastic.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
  2. Sony Xperia M2 Loudspeaker Replacement, Battery: adım 2, 3 resimden 1. Sony Xperia M2 Loudspeaker Replacement, Battery: adım 2, 3 resimden 2. Sony Xperia M2 Loudspeaker Replacement, Battery: adım 2, 3 resimden 3.
    • Disconnect the Battery Cable.
    • The battery is stuck to the phone fame. Use the white tape to remove it.
    • Li-Polymer Battery, 2230 mAh
    • Part number: LIS1551ERPC
    • Please SUBSCRIBE to my channel ツ
  3. Sony Xperia M2 Loudspeaker Replacement, Loudspeaker: adım 3, 3 resimden 1. Sony Xperia M2 Loudspeaker Replacement, Loudspeaker: adım 3, 3 resimden 2. Sony Xperia M2 Loudspeaker Replacement, Loudspeaker: adım 3, 3 resimden 3.
    • Remove the two T5 screws.
    • Use a plastic tool to unstuck the the Loudspeaker module from the Main frame.
  4. Sony Xperia M2 Loudspeaker Replacement: adım 4, 2 resimden 1. Sony Xperia M2 Loudspeaker Replacement: adım 4, 2 resimden 2.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
ZFix
191.341 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.541 adet Kılavuz yazıldı
Bir Yorum
For anyone doing this on an Xperia M2 Aqua: BE VERY CAREFUL! There’s strong adhesive foam around the microphone (which points forwards and sits under the screen on the Aqua, unlike the regular M2 where it points downwards). Try your best to detach the loudspeaker module from the mic/vibra/antenna PCB first, then very, VERY carefully pry under the PCB with a plastic tool in order to release the adhesive. If you try to remove the whole assembly by lifting from a corner and pulling it sideways, you WILL break the main microphone. Why they’d put such a delicate component in an accident-prone spot is beyond me. Don’t get me wrong, it’s not an expensive fix, but the inconvenience will get on your nerves haha.
Luis Alejandro Araúz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 18
Her zaman: 9,476
