Ana içeriğe geç
Sony Xperia M2 Touchscreen Replacement
Neye ihtiyacın var
    1. Sony Xperia M2 Touchscreen Replacement, Rear Cover: adım 1, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement, Rear Cover: adım 1, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement, Rear Cover: adım 1, 3 resimden 3.
      • Warm the Back Cover. You can use a hairdryer.
      • Be careful, the Cover is plastic.
      • Use a small suction cup and plastic tools for separating the Rear panel.
      • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia M2 Touchscreen Replacement, Battery: adım 2, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement, Battery: adım 2, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement, Battery: adım 2, 3 resimden 3.
      • Disconnect the Battery Cable.
      • The battery is stuck to the phone fame. Use the white tape to remove it.
      • Li-Polymer Battery, 2230 mAh
      • Part number: LIS1551ERPC
      • Please SUBSCRIBE to my channel ツ
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia M2 Touchscreen Replacement, Logic Board: adım 3, 2 resimden 1. Sony Xperia M2 Touchscreen Replacement, Logic Board: adım 3, 2 resimden 2.
      • Remove the SIM and the memory cards.
      • Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia M2 Touchscreen Replacement: adım 4, 1 resimden 1.
      • Disconnect one by one:
      • Touchscreen flex cable
      • Proximity sensor flex cable
      • Power on, Volume buttons cable
      • SIM & Micro SD flex cable
      • Coaxial antenna cable
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia M2 Touchscreen Replacement: adım 5, 2 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 5, 2 resimden 2.
      • Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector.
      • Put one plastic spudger between the Logic board and the Main frame.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia M2 Touchscreen Replacement: adım 6, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 6, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement: adım 6, 3 resimden 3.
      • Step one: move aside less the left side of the board - down.
      • Step two: the left side of the Logic board must go out of the main frame.
      • For this manipulation use only plastic tools.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia M2 Touchscreen Replacement, LCD Display, Touchscreen / Glass / Digitizer: adım 7, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement, LCD Display, Touchscreen / Glass / Digitizer: adım 7, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement, LCD Display, Touchscreen / Glass / Digitizer: adım 7, 3 resimden 3.
      • Let's first test the new spare parts.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia M2 Touchscreen Replacement: adım 8, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 8, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement: adım 8, 3 resimden 3.
      • Use a scotch tape for the broken glass.
      • Unstuck the LCD Display flex cable from the Main frame.
      • Now preheat the glass before removing. This will soften the adhesive and will make separating more easy.
      • You can use a hairdryer.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia M2 Touchscreen Replacement: adım 9, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 9, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement: adım 9, 3 resimden 3.
      • With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia M2 Touchscreen Replacement: adım 10, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 10, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement: adım 10, 3 resimden 3.
      • This is the Display Assembly.
      • The LCD Display and the Touchscreen are not firmly bonded, while some other other models.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Xperia M2 Touchscreen Replacement: adım 11, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 11, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement: adım 11, 3 resimden 3.
      • If your Touchscreen or LCD Display is OK, separate them carefully.
      • In our situation, both of them are broken.
      FixBot'a Sor
      Yorum Ekle
    6. Sony Xperia M2 Touchscreen Replacement: adım 12, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 12, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement: adım 12, 3 resimden 3.
      • Clean the frame from the remains of tape.
      • Install the LCD Display and the flex cable on its correct place.
      FixBot'a Sor
      Yorum Ekle
    7. Sony Xperia M2 Touchscreen Replacement: adım 13, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 13, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement: adım 13, 3 resimden 3.
      • We could not find adhesive sticker for this model, so We used universal adhesive tape 3M - 3 mm.
      • Don't forget to remove protectors from the LCD Display and from the inner side of the Touchscreen.
      FixBot'a Sor
      Yorum Ekle
    8. Sony Xperia M2 Touchscreen Replacement: adım 14, 3 resimden 1. Sony Xperia M2 Touchscreen Replacement: adım 14, 3 resimden 2. Sony Xperia M2 Touchscreen Replacement: adım 14, 3 resimden 3.
      • When finishing the assembly of the inner parts, use same technic to install the Back cover.
      FixBot'a Sor
      Yorum Ekle
Sonuç
40 farklı kişi bu kılavuzu tamamladı.
ZFix
197.378 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
334 Üyeler
3.155 adet Kılavuz yazıldı
18Kılavuz Yorumları
I successfuly repaired my Phone. The only Problem i had was that i proke the LCD as i was trying to Open the Phone. So take care when you open the phone an be very carefull!
Thank you Ifixit for this guide!
Fabian - Yanıt Paylaş
Followed Guide & completed without any errors. Also Step 2 "remove x4 screws" There's also x2 Screws on the board that needs removing.
Also The touch screen isn't exactly glued to the screen so does come of pretty easy but be very careful when using spudger to remove the glass as you could easily prod the touch screen. Apart from that thanks for the Guide it went well.
WILSON3000 - Yanıt Paylaş
Hi there. Thanks for the leaflet with the links that I got with my purchase. Things went really well, except for one thing. Not sure if you can help, but it would be great if you can.
Everything is connected and assembled, although not bonded yet. The problem I have is the touch screen buttons at the bottom of the screen (return/back, home, task navigation) are completely unresponsive. Is there anything you could advice to help please.
It might be worth knowing that with the phone in landscape (rather than portrait) the buttons seem to work, maybe suggesting that there is something at the bottom of the screen that's not quite right.
Thank you in advance of any response.
spooksfacebook - Yanıt Paylaş
bro you change whole part touch digitizer + lcd ???
shehroz - Yanıt Paylaş
I changed the broken touchscreen today... with success, except that during the operation, I broke the LCD! (I did not read the comments first!!!) Indeed, the screen was broken in many parts and as I wanted to unpaste some of the rather small parts (1-2cm wide), they pressed on the screen and broke it. It is not visible when switched off, but I could check that some broken parts correspond to the shape of some shards of glass when I switched it on and realize that I broke it.
A comment that might be useful: when you assemble again the microphone part, extend maximally the door of the SIM and the microSD, otherwise you may have difficulties to place it back, and do not forget the connector of the proximity detector.
Good luck!
Nicohoho - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 64
Her zaman: 88,822
