Ana içeriğe geç
Sony Xperia M4 Aqua Back Cover
Neye ihtiyacın var
  1. Sony Xperia M4 Aqua Back Cover, Back Cover: adım 1, 1 resimden 1.
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Back Cover: adım 2, 1 resimden 1.
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Back Cover: adım 3, 2 resimden 1. Sony Xperia M4 Aqua Back Cover: adım 3, 2 resimden 2.
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Back Cover: adım 4, 1 resimden 1.
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Brian McKalip
2.100 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-5, Lacy Spring 2016 USF Tampa, Team 4-5, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G5
3 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
Thanks. Do you know where to order a new back cover? Mine has shattered
Michael McNicholas - Yanıt
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - Yanıt
Reassembling just in reverse order you’ll  get a non-dust and non-waterproof device and not normally fixed rear cover.  You have to apply special Sony Xperia M4 Aqua E2303 Adhesive Sticker, 56BTUL0030A.
Andrey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 8,184
