Giriş
This is the step-by-step guide for replacing the Sony Xperia M4 Aqua rear camera.
Neye ihtiyacın var
Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
Remove the four hex head 3mm screws at each corner of the motherboard with a screwdriver.
Remove three pieces of the securing bracket using tweezers
This step is wrong. It’s actually two security brackets, not three, as long as you don’t break the one on the left/upper side. If you do it like it’s shown here you will break this part. The correct way to do this is remove the bracket on the right side, then remove the board with the other bracket still attached. Watch this video to get an idea: https://youtu.be/9o1DGKT76eo (interesting part starting at 1:50).
Detach the rear camera connector from the front of the motherboard.
Remove the rear camera with your fingers or tweezers.
5 farklı kişi bu kılavuzu tamamladı.
