Ana içeriğe geç
Sony Xperia S Disassembly
Neye ihtiyacın var
  1. Sony Xperia S Disassembly, Sony Xperia S Disassembly: adım 1, 1 resimden 1.
    • Remove the case (back cover)
  2. Sony Xperia S Disassembly: adım 2, 1 resimden 1.
    • Remove the screws in the indicated areas (Red Markings) with a screwdriver.
  3. Sony Xperia S Disassembly: adım 3, 1 resimden 1.
    • Then, detach the first bus (indicated with the red circle) to fully detach the case.
  4. Sony Xperia S Disassembly: adım 4, 1 resimden 1.
    • Then, you will see the battery, let's proceed to remove the battery.
  5. Sony Xperia S Disassembly: adım 5, 1 resimden 1.
    • To remove the battery, remove the two buses pointed out in red.
  6. Sony Xperia S Disassembly: adım 6, 1 resimden 1.
    • After removing the buses, we can remove the camera and the motherboard. Proceed to remove the motherboard.
  7. Sony Xperia S Disassembly: adım 7, 1 resimden 1.
    • Finally, after removing the motherboard, you have fully dismantled the phone.
Sonuç
To reassemble your device, follow the instructions in reverse order
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
es en
100%
Henry Ko dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
sergiolisto95
118 İtibar
1 Kılavuz yazıldı
3 Yorum
hi..my xperia s totally crashed..it is not working at all..is there any way to get the data from the sd card..!!??please help..if i disassembled it ..can i run the sd card on another device or something like that or any thing ..please help..:(
soma ana - Yanıt
Hi Soma Ana,
Assuming that your SD card has not been corrupted or anything, you can plug it into your computer or another device (though I would personally recommend you to look from your computer) and find your old files.
Henry Ko -
estoy en la misma situación, pudiste encontrar la sd?
Leopold Fitz -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 3,064
