Ana içeriğe geç
Sony Xperia Sola Battery Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Sony Xperia Sola Battery Replacement, Lay the phone as shown.: adım 1, 1 resimden 1.
    • Place phone down with screen side down and camera side facing up as shown.
  2. Sony Xperia Sola Battery Replacement, Remove the back cover.: adım 2, 1 resimden 1.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  3. Sony Xperia Sola Battery Replacement, Remove the screws.: adım 3, 3 resimden 1. Sony Xperia Sola Battery Replacement, Remove the screws.: adım 3, 3 resimden 2. Sony Xperia Sola Battery Replacement, Remove the screws.: adım 3, 3 resimden 3.
    • Locate and remove the five (5) screws on the phone, using the 26 Bit Kit. The screws are at the top and the bottom of the phone as shown.
  4. Sony Xperia Sola Battery Replacement, Remove bottom white cover.: adım 4, 2 resimden 1. Sony Xperia Sola Battery Replacement, Remove bottom white cover.: adım 4, 2 resimden 2.
    • Pry off the bottom white cover by using the opening tool as a lever.
  5. Sony Xperia Sola Battery Replacement, Remove more screws.: adım 5, 2 resimden 1. Sony Xperia Sola Battery Replacement, Remove more screws.: adım 5, 2 resimden 2.
    • Locate and remove the 2 additional screws, using the 26 Bit Kit, that are revealed. These are marked as shown.
  6. Sony Xperia Sola Battery Replacement, Remove black cover.: adım 6, 2 resimden 1. Sony Xperia Sola Battery Replacement, Remove black cover.: adım 6, 2 resimden 2.
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  7. Sony Xperia Sola Battery Replacement, Disconnect the battery's circuit.: adım 7, 1 resimden 1.
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  8. Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: adım 8, 3 resimden 1. Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: adım 8, 3 resimden 2. Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: adım 8, 3 resimden 3.
    • Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  9. Sony Xperia Sola Battery Replacement, Remove the additional power circuit.: adım 9, 1 resimden 1.
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  10. Sony Xperia Sola Battery Replacement, Repeat for the circuit on the top end of the battery.: adım 10, 2 resimden 1. Sony Xperia Sola Battery Replacement, Repeat for the circuit on the top end of the battery.: adım 10, 2 resimden 2.
    • Use the tweezers to lift up on the circuit located at the top left.
  11. Sony Xperia Sola Battery Replacement, Remove the motherboard.: adım 11, 1 resimden 1.
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
  12. Sony Xperia Sola Battery Replacement, Remove and replace the battery.: adım 12, 3 resimden 1. Sony Xperia Sola Battery Replacement, Remove and replace the battery.: adım 12, 3 resimden 2. Sony Xperia Sola Battery Replacement, Remove and replace the battery.: adım 12, 3 resimden 3.
    • To remove battery, slide a flat object under the battery and lift. The plastic opening tool will be the best tool for this.
    • It is possible that the battery may be glued onto the phone. If this is the case, slightly heat the glue to allow removal without breaking the battery. To heat the glue, use a simple hair dryer, but be very careful as not to overheat the phone and damage any components.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Cary Drew
866 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Brown Fall 2014 USF Tampa, Team 1-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G1
4 Üyeler
3 Yorum
Thanks, battery successfully changed :-)
martinslunecko - Yanıt
Thanx will do that when i get areplacement battery!
ndiwenijb - Yanıt
hello where i can find a new battery ?
minigamer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 3,231
