Giriş
If your camera broke or doesn't work you may need to replace it from the board. This will show you how to do it.
Neye ihtiyacın var
Place phone down with screen side down and camera side facing up as shown.
Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
Bu adımda kullanılan alet:Tweezers$4.99
Using the tweezers remove the camera from the power source.
Pick up board and remove camera module. The module should seem to just pop out.
2 farklı kişi bu kılavuzu tamamladı.
