Ana içeriğe geç
Sony Xperia Sola LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Xperia Sola LCD Screen Replacement, Lay the phone as shown.: adım 1, 2 resimden 1. Sony Xperia Sola LCD Screen Replacement, Lay the phone as shown.: adım 1, 2 resimden 2.
    • Place phone down with screen side down and camera side facing up as shown.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  2. Sony Xperia Sola LCD Screen Replacement, Remove the screws.: adım 2, 3 resimden 1. Sony Xperia Sola LCD Screen Replacement, Remove the screws.: adım 2, 3 resimden 2. Sony Xperia Sola LCD Screen Replacement, Remove the screws.: adım 2, 3 resimden 3.
    • Locate and remove the five (5) screws on the phone, using a screwdriver. The screws are at the top and the bottom of the phone as shown.
  3. Sony Xperia Sola LCD Screen Replacement, Remove bottom white cover.: adım 3, 2 resimden 1. Sony Xperia Sola LCD Screen Replacement, Remove bottom white cover.: adım 3, 2 resimden 2.
    • Pry off the bottom white cover by using the opening tool as a lever.
  4. Sony Xperia Sola LCD Screen Replacement, Remove more screws.: adım 4, 2 resimden 1. Sony Xperia Sola LCD Screen Replacement, Remove more screws.: adım 4, 2 resimden 2.
    • Locate and remove the 2 additional screws, using the Torx screwdriver, that are revealed. These are marked as shown.
  5. Sony Xperia Sola LCD Screen Replacement, Remove black cover.: adım 5, 2 resimden 1. Sony Xperia Sola LCD Screen Replacement, Remove black cover.: adım 5, 2 resimden 2.
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  6. Sony Xperia Sola LCD Screen Replacement, Disconnect the battery's circuit.: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  7. Sony Xperia Sola LCD Screen Replacement, Remove the phone's inner back cover.: adım 7, 3 resimden 1. Sony Xperia Sola LCD Screen Replacement, Remove the phone's inner back cover.: adım 7, 3 resimden 2. Sony Xperia Sola LCD Screen Replacement, Remove the phone's inner back cover.: adım 7, 3 resimden 3.
    • Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  8. Sony Xperia Sola LCD Screen Replacement, Remove the additional power circuit.: adım 8, 1 resimden 1.
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  9. Sony Xperia Sola LCD Screen Replacement, Repeat for the circuit on the top end of the battery.: adım 9, 2 resimden 1. Sony Xperia Sola LCD Screen Replacement, Repeat for the circuit on the top end of the battery.: adım 9, 2 resimden 2.
    • Use the tweezers to lift up on the circuit located at the top left.
  10. Sony Xperia Sola LCD Screen Replacement, Remove the motherboard.: adım 10, 1 resimden 1.
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
  11. Sony Xperia Sola LCD Screen Replacement, Remove the LCD screen.: adım 11, 3 resimden 1. Sony Xperia Sola LCD Screen Replacement, Remove the LCD screen.: adım 11, 3 resimden 2. Sony Xperia Sola LCD Screen Replacement, Remove the LCD screen.: adım 11, 3 resimden 3.
    • Use either the plastic opener or the spudger to slid in the side. It will go in between the LCD screen and the spot you pulled the board off of.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Cary Drew
866 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Brown Fall 2014 USF Tampa, Team 1-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,190
