Ana içeriğe geç
Giriş
This guide will assist you in taking apart the phone to remove the circuit board as this is a required step in almost all of the part replacements for this camera.
  1. Place phone down with screen side down and camera side facing up as shown.
    • Place phone down with screen side down and camera side facing up as shown.
  2. Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  3. Locate and remove the five (5) screws on the phone, using the 26 Bit Kit. The screws are at the top and the bottom of the phone as shown. Locate and remove the five (5) screws on the phone, using the 26 Bit Kit. The screws are at the top and the bottom of the phone as shown. Locate and remove the five (5) screws on the phone, using the 26 Bit Kit. The screws are at the top and the bottom of the phone as shown.
    • Locate and remove the five (5) screws on the phone, using the 26 Bit Kit. The screws are at the top and the bottom of the phone as shown.
  4. Using the opening tool, slide it under white bottom and push toward yourself to remove. Using the opening tool, slide it under white bottom and push toward yourself to remove.
    • Using the opening tool, slide it under white bottom and push toward yourself to remove.
  5. Locate and remove the 2 additional screws, using the 26 Bit Kit, that are revealed. These are marked as shown. Locate and remove the 2 additional screws, using the 26 Bit Kit, that are revealed. These are marked as shown.
    • Locate and remove the 2 additional screws, using the 26 Bit Kit, that are revealed. These are marked as shown.
  6. Locate the black cover on the bottom left of phone. Slide the flat small object off using the opening tool by placing it under the right side and lifting up to remove it. The cover is marked in one photo. Locate the black cover on the bottom left of phone. Slide the flat small object off using the opening tool by placing it under the right side and lifting up to remove it. The cover is marked in one photo.
    • Locate the black cover on the bottom left of phone. Slide the flat small object off using the opening tool by placing it under the right side and lifting up to remove it. The cover is marked in one photo.
  7. Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  8. Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover.  You can also slide the spudger in from the top. Once the cover is loose,  lift it off the phone. The side buttons may feel a bit sticky, but this is normal. Once the cover is loose,  lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
    • Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  9. Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  10. Use the tweezers to lift up on the circuit located at the top left. Use the tweezers to lift up on the circuit located at the top left.
    • Use the tweezers to lift up on the circuit located at the top left.
  11. Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Cary Drew
866 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-1, Brown Fall 2014 USF Tampa, Team 1-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S1G1
4 Üyeler
2 Yorum
Some of these pictures are too blurry.
Dan Brown - Yanıt
You need written instructions for each step.
Dan Brown - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,058
