Ana içeriğe geç
Giriş
This guide can help you remove the front facing camera.
  1. Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  4. Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  5. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  6. Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
    • Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Christina Wojaczyk
1.429 İtibar
7 adet Kılavuz yazıldı
Takım
USF Tampa, Team 13-3, Staggers Fall 2014 USF Tampa, Team 13-3, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G3
3 Üyeler
2 Yorum
From camera icon is not available
rameshmax - Yanıt
Front camera is not available
rameshmax - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 7
Her zaman: 3,743
