Ana içeriğe geç
Sony Xperia TL Auxiliary Cord Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Sony Xperia TL Auxiliary Cord Replacement, Remove Top Plastic Section: adım 1, 3 resimden 1. Sony Xperia TL Auxiliary Cord Replacement, Remove Top Plastic Section: adım 1, 3 resimden 2. Sony Xperia TL Auxiliary Cord Replacement, Remove Top Plastic Section: adım 1, 3 resimden 3.
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Auxiliary Cord Replacement, Remove Bottom Plastic Section: adım 2, 2 resimden 1. Sony Xperia TL Auxiliary Cord Replacement, Remove Bottom Plastic Section: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Auxiliary Cord Replacement, Unscrewing the Back Off: adım 3, 3 resimden 1. Sony Xperia TL Auxiliary Cord Replacement, Unscrewing the Back Off: adım 3, 3 resimden 2. Sony Xperia TL Auxiliary Cord Replacement, Unscrewing the Back Off: adım 3, 3 resimden 3.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Auxiliary Cord Replacement, Loud Speaker: adım 4, 3 resimden 1. Sony Xperia TL Auxiliary Cord Replacement, Loud Speaker: adım 4, 3 resimden 2. Sony Xperia TL Auxiliary Cord Replacement, Loud Speaker: adım 4, 3 resimden 3.
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Auxiliary Cord Replacement, Sony Xperia TL Auxiliary Cord Replacement: adım 5, 2 resimden 1. Sony Xperia TL Auxiliary Cord Replacement, Sony Xperia TL Auxiliary Cord Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam Giniger
1.303 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 57
