Ana içeriğe geç
Sony Xperia TL Battery Replacement
Neye ihtiyacın var
  1. Sony Xperia TL Battery Replacement, Remove Top Plastic Section: adım 1, 3 resimden 1. Sony Xperia TL Battery Replacement, Remove Top Plastic Section: adım 1, 3 resimden 2. Sony Xperia TL Battery Replacement, Remove Top Plastic Section: adım 1, 3 resimden 3.
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Battery Replacement, Remove Bottom Plastic Section: adım 2, 2 resimden 1. Sony Xperia TL Battery Replacement, Remove Bottom Plastic Section: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Battery Replacement, Unscrewing the Back Off: adım 3, 3 resimden 1. Sony Xperia TL Battery Replacement, Unscrewing the Back Off: adım 3, 3 resimden 2. Sony Xperia TL Battery Replacement, Unscrewing the Back Off: adım 3, 3 resimden 3.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Battery Replacement, Battery: adım 4, 3 resimden 1. Sony Xperia TL Battery Replacement, Battery: adım 4, 3 resimden 2. Sony Xperia TL Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Adam Giniger
1.303 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G4
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Is it necessary to back up the phone before replacing the battery, or will the settings be preserved?
r3woods - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,035
