Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Giriş
Removing this part is hard for the first time because the manufacturer used adhesive to keep it in place.
  1. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off.
    • Use the plastic opening tool to pry the top plastic section off.
  2. Use the plastic opening tool to pry the bottom plastic section off. Use the plastic opening tool to pry the bottom plastic section off.
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Remove the four 5mm screws. Use the plastic opening tool to pry off the back. Use the plastic opening tool to pry off the back.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Use the plastic opening tool to detach the ribbon running across the battery. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Adam Giniger
1.259 İtibar
8 adet Kılavuz yazıldı
Takım
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G4
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Is it necessary to back up the phone before replacing the battery, or will the settings be preserved?
r3woods - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,846
