Ana içeriğe geç
Sony Xperia TL Display Assembly Replacement
Neye ihtiyacın var
  1. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: adım 1, 3 resimden 1. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: adım 1, 3 resimden 2. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: adım 1, 3 resimden 3.
    • Use the plastic opening tool to pry the top plastic section off.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: adım 2, 2 resimden 1. Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry the bottom plastic section off.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: adım 3, 3 resimden 1. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: adım 3, 3 resimden 2. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: adım 3, 3 resimden 3.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Xperia TL Display Assembly Replacement, Loud Speaker: adım 4, 3 resimden 1. Sony Xperia TL Display Assembly Replacement, Loud Speaker: adım 4, 3 resimden 2. Sony Xperia TL Display Assembly Replacement, Loud Speaker: adım 4, 3 resimden 3.
    • Use the plastic opening tool to remove the loud speaker module.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Xperia TL Display Assembly Replacement, Battery: adım 5, 3 resimden 1. Sony Xperia TL Display Assembly Replacement, Battery: adım 5, 3 resimden 2. Sony Xperia TL Display Assembly Replacement, Battery: adım 5, 3 resimden 3.
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Xperia TL Display Assembly Replacement, Battery Harness: adım 6, 3 resimden 1. Sony Xperia TL Display Assembly Replacement, Battery Harness: adım 6, 3 resimden 2. Sony Xperia TL Display Assembly Replacement, Battery Harness: adım 6, 3 resimden 3.
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Xperia TL Display Assembly Replacement: adım 7, 1 resimden 1.
    • The final step is taking the entire harness off of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Sony Xperia TL Display Assembly Replacement, Motherboard: adım 8, 3 resimden 1. Sony Xperia TL Display Assembly Replacement, Motherboard: adım 8, 3 resimden 2. Sony Xperia TL Display Assembly Replacement, Motherboard: adım 8, 3 resimden 3.
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
    FixBot'a Sor
    Yorum Ekle
  9. Sony Xperia TL Display Assembly Replacement, Ear Speaker: adım 9, 1 resimden 1.
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
    FixBot'a Sor
    Yorum Ekle
  10. Sony Xperia TL Display Assembly Replacement, Display Assembly: adım 10, 1 resimden 1.
    • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam Giniger
1.303 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G4
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 873
