Ana içeriğe geç
Sony Xperia TL Headphone Jack Replacement
Neye ihtiyacın var
  1. Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: adım 1, 3 resimden 1. Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: adım 1, 3 resimden 2. Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: adım 1, 3 resimden 3.
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Headphone Jack Replacement, Remove Bottom Plastic Section: adım 2, 2 resimden 1. Sony Xperia TL Headphone Jack Replacement, Remove Bottom Plastic Section: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: adım 3, 3 resimden 1. Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: adım 3, 3 resimden 2. Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: adım 3, 3 resimden 3.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Headphone Jack Replacement, Battery: adım 4, 3 resimden 1. Sony Xperia TL Headphone Jack Replacement, Battery: adım 4, 3 resimden 2. Sony Xperia TL Headphone Jack Replacement, Battery: adım 4, 3 resimden 3.
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Headphone Jack Replacement, Sony Xperia TL Auxiliary Cord Replacement: adım 5, 2 resimden 1. Sony Xperia TL Headphone Jack Replacement, Sony Xperia TL Auxiliary Cord Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Headphone Jack Replacement, Motherboard: adım 6, 3 resimden 1. Sony Xperia TL Headphone Jack Replacement, Motherboard: adım 6, 3 resimden 2. Sony Xperia TL Headphone Jack Replacement, Motherboard: adım 6, 3 resimden 3.
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  7. Sony Xperia TL Headphone Jack Replacement, Headphone Jack: adım 7, 1 resimden 1.
    • Use the plastic opening tool to detach the headphone jack from the motherboard.
    • Remove the motherboard and slide the headphone jack out of its slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan Laneau
435 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 250
