Neye ihtiyacın var
Place the plastic removal tool in the corner of the object.
Slide the plastic removal tool along the edges.
25 farklı kişi bu kılavuzu tamamladı.
14 Yorum
Helps me with info I need for a screen replacement. I'll post pics when I complete it. need a new screen first, hard to find for that model.
any one actially got any andswers about were to actually get this replacement battery.. WHY OH WHY do the tuitorial without mentiong were to find the fleeping replacement?????
Sveiki
Norėčiau paklausti
Mano Sony Xperia Z po valandos darbo ( pdf failų skaitymas ar filmo žiūrėjimas) parodo pranešimą , kad įrenginys perkaito ir yra išjungiamas.
Anksčiau to nebūdavo. Ar gali taip būti dėl baterijos senėjimo proceso ?
Pagarbiai
Sigitas
nemsig@yahoo.com
nemsig -
Hello
I want to ask
My Sony Xperia Z after hours of work (pdf file reading or watching a movie) displays a message that the device is overheated and shut down.
It did not exist before. Could this be due to the battery aging process?
Sincerely,
Sigitas
nemsig -
You forgot to soften and clean the glue holding the unit together
You didnt suggest using any waterproofing seals on the rebuild
You didnt specify how to determine which battery is the correct one. Two types are available for the Sony tablet/
I know what you mean about the battery. For a major brand, Sony are shite when it comes to after sales service and parts.
Ive seen the batteries advertised via Google search and on Amazon. Problem is, they show a very different battery to the one in this guide. They all seem to be made in China, unbranded. It’s a risk, certainly.
This looks like the early Xperia tablet SGP311. Later models use a different battery.
Hei. Jeg har et Sony Xperia Tablet Z 4. Utføres batteribyttet på samme måte??
is it possible to connect the battery on another connector on the mainboard? Mine got broken during disconnecting zhe cables and totally got off the board....+#
