Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If your phone's battery is not working or not charging, follow these steps to help guide you through the process or removing and replacing the battery
Neye ihtiyacın var
Set the phone screen down on a clean flat, surface.
Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
2 farklı kişi bu kılavuzu tamamladı.
