Ana içeriğe geç
Sony Xperia U Motherboard Replacement
Neye ihtiyacın var
  1. Sony Xperia U Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Motherboard Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Remove the bottom cover of the phone using the plastic opening tool.
  4. Sony Xperia U Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the five 5.47mm and one 5.18mm Torx head screws using a Phillips #0 screwdriver.
  5. Sony Xperia U Motherboard Replacement: adım 5, 1 resimden 1.
    • Carefully remove the back cover using the plastic opening tool.
  6. Sony Xperia U Motherboard Replacement: adım 6, 1 resimden 1.
    • Pry up on the right side of the motherboard using the plastic opening tool.
  7. Sony Xperia U Motherboard Replacement: adım 7, 1 resimden 1.
    • Carefully detach the flex cable using a pair of tweezers.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bader
545 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Leahy Fall 2014 USF Tampa, Team 7-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S7G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,845
