Ana içeriğe geç
Sony Xperia U Speaker Replacement
Neye ihtiyacın var
  1. Sony Xperia U Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Speaker Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Speaker Replacement, Headphone Jack: adım 3, 1 resimden 1.
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Speaker Replacement: adım 5, 1 resimden 1.
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Speaker Replacement: adım 6, 1 resimden 1.
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
  7. Sony Xperia U Speaker Replacement, Speaker: adım 7, 1 resimden 1.
    • Using the tweezers, remove the loudspeaker module by firmly grasping it on one side, then slowly and carefully pulling the module in an upward direction.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bader
545 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Leahy Fall 2014 USF Tampa, Team 7-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S7G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 915
