Giriş
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
Neye ihtiyacın var
Pry up the copper connector next to the battery with the plastic opening tool.
Use the nylon spudger to pry up the black camera connector from the motherboard.
Bir başkası bu kılavuzu tamamladı.
