Ana içeriğe geç
Sony Xperia XA Battery Replacement
Neye ihtiyacın var
    1. Sony Xperia XA Battery Replacement, Back Cover: adım 1, 1 resimden 1.
      • Apply heat on the back surface of the phone.
      • Continue to heat the device as needed throughout the replacement process.
      • The device can get very hot, so be careful when handling it.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia XA Battery Replacement: adım 2, 1 resimden 1.
      • Stick the small suction cup on the bottom half of the back surface of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia XA Battery Replacement: adım 3, 3 resimden 1. Sony Xperia XA Battery Replacement: adım 3, 3 resimden 2. Sony Xperia XA Battery Replacement: adım 3, 3 resimden 3.
      • With the bottom of the device facing you, lift up on the suction cup handle.
      • Use the plastic opening tool around all sides to pry off the back cover.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia XA Battery Replacement: adım 4, 3 resimden 1. Sony Xperia XA Battery Replacement: adım 4, 3 resimden 2. Sony Xperia XA Battery Replacement: adım 4, 3 resimden 3.
      • Pull the back of the phone case away from the device.
      • You will hear popping sounds of glue being ripped from the phone.
      • You will hear the sound of the back unlatching from the device.
      • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
      • RAF antenna may be attached to the back cover upon removal.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Xperia XA Battery Replacement: adım 5, 1 resimden 1.
      • Apply heat to the copper RAF antenna.
      • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
      FixBot'a Sor
      Yorum Ekle
    6. Sony Xperia XA Battery Replacement: adım 6, 1 resimden 1.
      • Peel back the RAF antenna.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia XA Battery Replacement, Battery: adım 7, 3 resimden 1. Sony Xperia XA Battery Replacement, Battery: adım 7, 3 resimden 2. Sony Xperia XA Battery Replacement, Battery: adım 7, 3 resimden 3.
      • Peel back the black tabs on the battery.
      • This may require some force as you are breaking the adhesive seal.
      • You will need to apply more adhesive for the reassembly.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia XA Battery Replacement: adım 8, 2 resimden 1. Sony Xperia XA Battery Replacement: adım 8, 2 resimden 2.
      • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia XA Battery Replacement: adım 9, 1 resimden 1.
      • Use a plastic opening tool to get under the battery and pry it up.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia XA Battery Replacement: adım 10, 1 resimden 1.
      • Lift the battery out with your hands.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Cassidy Davis
669 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G2
4 Üyeler
56 adet Kılavuz yazıldı
1Rehber Yorum
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
Mike Jurkiewicz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 5,994
