Ana içeriğe geç
Sony Xperia XA Loudspeaker Replacement
Neye ihtiyacın var
  1. Sony Xperia XA Loudspeaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Loudspeaker Replacement: adım 2, 1 resimden 1.
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Loudspeaker Replacement: adım 3, 3 resimden 1. Sony Xperia XA Loudspeaker Replacement: adım 3, 3 resimden 2. Sony Xperia XA Loudspeaker Replacement: adım 3, 3 resimden 3.
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Loudspeaker Replacement: adım 4, 3 resimden 1. Sony Xperia XA Loudspeaker Replacement: adım 4, 3 resimden 2. Sony Xperia XA Loudspeaker Replacement: adım 4, 3 resimden 3.
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Loudspeaker Replacement: adım 5, 1 resimden 1.
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Loudspeaker Replacement: adım 6, 1 resimden 1.
    • Peel back the RAF antenna.
  7. Sony Xperia XA Loudspeaker Replacement, Loudspeaker: adım 7, 2 resimden 1. Sony Xperia XA Loudspeaker Replacement, Loudspeaker: adım 7, 2 resimden 2.
    • Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
  8. Sony Xperia XA Loudspeaker Replacement: adım 8, 2 resimden 1. Sony Xperia XA Loudspeaker Replacement: adım 8, 2 resimden 2.
    • Push back the two retaining tabs on the top of the loudspeaker with the spudger.
  9. Sony Xperia XA Loudspeaker Replacement: adım 9, 1 resimden 1.
    • Pry the loudspeaker up with the spudger.
  10. Sony Xperia XA Loudspeaker Replacement: adım 10, 1 resimden 1.
    • Remove the loudspeaker with your hands.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Stephen Rock
230 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 502
