Giriş
This guide will show you how to remove the loudspeaker from your Sony Xperia XA1 Ultra. The loudspeaker needs to be replaced if sound is no longer emitted from your phone. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws, and a spudger is used to lift and remove components of the phone.
Neye ihtiyacın var
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Bir başkası bu kılavuzu tamamladı.
