Ana içeriğe geç
Sony Xperia XZ2 LCD Screen Replacement
Neye ihtiyacın var
    1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
      • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
      • The phone gets very hot and can hurt the user handling it.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia XZ2 LCD Screen Replacement: adım 2, 3 resimden 1. Sony Xperia XZ2 LCD Screen Replacement: adım 2, 3 resimden 2. Sony Xperia XZ2 LCD Screen Replacement: adım 2, 3 resimden 3.
      • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
      • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia XZ2 LCD Screen Replacement: adım 3, 2 resimden 1. Sony Xperia XZ2 LCD Screen Replacement: adım 3, 2 resimden 2.
      • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
      • The screen is still attached by a connector, so do not pull the pieces apart.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia XZ2 LCD Screen Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      $3.99
      • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Xperia XZ2 LCD Screen Replacement: adım 5, 1 resimden 1.
      • Gently remove the connector by using a spudger to pop it off.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Matthew Ionescu
445 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G5, White Winter 2019 Cal Poly, Team S19-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S19G5
4 Üyeler
35 adet Kılavuz yazıldı
4Kılavuz Yorumları
Worked perfectly fine for my xz2 compact
Maria Schrenk - Yanıt Paylaş
Hi, someone knows how to glue it back. I read that if I use B-6000 glue it will damage my screen.
Diego Covenas - Yanıt Paylaş
Double-sided adhesive should do the trick. For example 2mm Universal 3M Adhesive Tape should be preferred to glue.
Célestin Taramarcaz - Yanıt Paylaş
The XZ2 Compact has the same screen connector+clip.
My screen came without the upper speaker grille (plastic+fabric). When I tried to remove the glue from the old one the fabric got delaminated from the plastic. Tip: Check if the grille is in place before gluing back!
Dimitrios Josef Moustos - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 31
Son 30 gün: 99
Her zaman: 11,831
